Raptor Mono VESC XML File Wanted
VESC went bad. A previously VESC order arrived for a different build. While warranty stuff is worked out, I’d like to get the Raptor up and running. Any have a saved config file to post? I can’t get info off of the old VESC and I can’t find a file or complete settings online.
You should do motor detection for you own motor, I wouldn’t rely on someone else’s motor config. If you want usable motor limits try these:
Motor Max: 60A Motor min (regen): -50A Battery Max: Depends on battery (60A max for SCP3, though I’d go lower) Battery Min (regen): Depends on battery (-12A max for SCP3) Absolute Max: 130A (default)
