Can you post some detailed photos with the pcb?
Immage 22&23 What are these parts called the big one and the one behind that. As need them replacing if you can help point me in the right direction.
Hi, I would like to purchase the gears this item is it still available?
Hi. I just brought a razor X Longboard. I’m thinking of getting a new motor that is a 40to60 volt and putting it straight in. Then I’ll make a 42 to 52 volt battery or just add another razor lg 21 volt battery. At least it will be kept original. The only other thing I think needs to be changed is the conpacitor to handle the voltage change to the mother board. Then I’ll have a razor X long board which will only look like it has a bigger battery and it will go alot faster too… Hopefully at least 30kmh instead of 16 kmh. What do you think about all this as I’m not a electrician but I did a bit of study and this should work fine. I only thing I don’t understand is the conpacitor part… I do know to add the exact same battery. I’ll have to make sure I wire it up so it gives more volts and not range. Never done it before so I hope it all works???!!!
My brother and I both aquired two razor x cruiser. both did not have remote receivers and chargers. I bought a new remote for a dual motor set up thinking it would work. i also have two hoover boards. one has been taken apart. the remote i bought does not sync with the razor (da i know) also the battery is at like 3v. i have plenty of power drill batteries. i also bough a long board and have put the razor guts onto the long board in hopes to have a esk8. to try it out of course. i have a 3d printer and can make stuff if needed. help is needed.
