Hello,
I’ve been working on setting up a controller for VESC using an arduino board.
I am using the Servo library to send PWM signals to the VESC but I am having trouble tuning it.
I have set the min and max pulse width from 1ms to 2ms in VESC PPM tab and also in my arduino program but VESC seems to respond only to a small range of values between 1.5ms and 1.6ms. Anything above that value gives the same speed.
Am I doing sth wrong? Is it suppose to be like that
I have attached my arduino code as well. It receives commands over bluetooth in the format “value in microseconds” followed by “n”
#include <Servo.h>
#include <SoftwareSerial.h>
#include <Arduino.h>
SoftwareSerial mySerial(5, 6);
Servo myservo; // create servo object to control a servo
double pos = 0; // variable to store the servo position
int delayTime = 15; // this variable sets the delay time between each step
String inString = "";
int prev = 1500;
char tbs[16];
void setup() {
myservo.attach(9, 1000, 2000); // attaches the servo on pin 9 to the servo object
myservo.writeMicroseconds(1500); // sets the servo to mid point
mySerial.begin(115200);
void loop() {
if (mySerial.available())
int inChar = mySerial.read();
if (isDigit(inChar)) {
inString += (char)inChar;
if (inChar == 'n') {
int x = inString.toInt();
if (x >= 1000 && x <= 2000)
sprintf(tbs, "Current input value %d", x);
mySerial.println(tbs);
sprintf(tbs, "Prev input value %d", prev);
if (prev <= x)
mySerial.println("Forward");
for (pos = prev; pos <= x; pos += 1) { // accelerates from prev position to current one
myservo.writeMicroseconds(pos); // tell servo to go to position in variable 'pos'
delay(delayTime); // delays the time before moving to the next position
prev = x;
else
mySerial.println("Back");
for (pos = prev; pos >= x; pos -= 1) { // decelerates from prev position to current one
prev = x;
inString = "";
