Which pins to short when re sinking the mini trigger?
I spent years keeping that little plug handy but it’s gone
In your photo, it’s the bottom-right and bottom-left
Ugh. W two receivers and three transmiters, and found the plug. No binding happening if u have any ideas.
Turn on board w receiver plugged in and the binding plug in 4
Turn on receiver n push bind button.
Still blinking fast. Tried every combo
I think you have to hold the bind Button as turn the remote on
flip the part on the vesc. i had the same issue
Plug only goes one way into Vesc. Ppm plug
It says turn on receiver then bind button but I’ll try
wait nvm. i keep on thinking abt something else. flip the one on the reciever maybe?
u could also try putting it in channel 2 maybe. thats what happened with me.
Weird. Bonded by holding bind button while turning on… but no action. Didn’t say that in instructions.
Ha. I helped with a thing
I can bind the different transmitters if I hold the button when turn the trans on… all lights on…but no throttle happening. I’ll watch the movie. You almost helped @Skunk. The semblance of help but no throttle
Try switching channels?
I accidentally got mine on backwards when swapping receivers
He didn’t even push the bind button in the video and worked!
ikr. 10char
check the ppm cable and the facing of it on the vesc.
i didn’t need to either
Only goes in one way.
black facing the left?
All lights up no throttle. With both trans.
