you can always test your receiver out by plugging it into a USB header. They supply 5 V. Just be sure to be using the correct pins. It will say what’s what on your motherboard
Edit: You could also get a USB cable. Cut it and use the Red for + and Black for GRND, wire this to a servo plug and plug your receiver into a computer USB port or even a USB charger to check power
