Recommendation for multimeter and bench top power supply
So I currently use a really cheap multimeter which mostly gets the job done. It did cost me a night’s sleep a couple weeks back where it started giving unusually high voltage readings while I built my battery pack. That proved to be because I hadn’t changed the batteries.
Nonetheless - I use it quite often and I’d like to get something a little more “pro-grade”. Then I looked at the price of Fluke multimeters and realised I probably want something “semi-pro” :joy:
What are you guys using? And recommendations?
And also, does anybody use bench top power supplies? The ones you can dial in voltage and current, and some I think switch between ac and dc? I used one all the time when I did electronics and physics at high school. I’ve often thought one would come in handy when tinkering with various electrical projects.
This sort of thing:
I have a Fluke multi-meter, but it stays on my bench. This is the one I carry around. https://www.amazon.com/gp/product/B01KBN5I0W/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
This is the lab power supply I use. As long as you make sure your charge ports are the same accross all of your boards you can charge multiple voltage levels with one charger/ https://www.amazon.com/gp/product/B00AXL7UJA/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
On top of @mmaner recommendation, get the super fine test leads if you have the budget.
https://www.amazon.com/dp/B01A6T8W2M/ref=sspa_dk_detail_4?psc=1&pd_rd_i=B01A6T8W2M&pd_rd_w=C9Slu&pf_rd_p=f0dedbe2-13c8-4136-a746-4398ed93cf0f&pd_rd_wg=ynayQ&pf_rd_r=MY1YWW41ADW4A0W7CSS6&pd_rd_r=88f47455-ffb7-11e8-9fc1-87cf5b4d0ae5
It will help wit troubleshooting the pcb board if you need to.
I have the UNI-T multimeter and I’m happy with it. I have done some research before buying and this one is supposed to be a good value for the money. The 22000 resolution is really nice and not a common feature in this price range.
