Hey guys, i am quite new at this. I am working on an all-terrain e-skate and didnt quite find a suggested drivetrain for it. Im planning the top speed to reach around 45Kph and this is what i am planning to use: (which affect the top speed)
2X KEDA 63-64 190KV Brushless Outrunner 10S 2000W
6s3p Lipo (33.3v)
6"-8" wheels
So my main question is, what would be a good ratio for this build so i get enough torque and still reach around 45Kph? Also what is a good distance between pulley’s centers ? Pulleys number of teeth? Pitch? And belt width?
6s and only 3p. It’s going to sag pretty bad and won’t have that great of acceleration.
Recommend 10s4p minimum if you want to push 6in AT tires. Change your avg energy use up to 30wh/mi as that seems to be the average for 6in AT boards. Start with your drive pulley teeth number based off availability, (most shops sell 16T drive, so that’s a good starting point).
Then do the driven pulley, 60-80T should do it. I run 6in tires with 16/66 gears and wide belts. 12mm I think.
Now if you are using street wheels (90-100mm) the driven pulley would change cause you can’t fit 66T on a small tire like that.
Plenty of torque and speed. Max speed is somewhere over 33mph, never tried to go over 33, 33 was too fast for me. Id like to increase to 15/90 but then the gear is getting pretty big.
