Still moving forward.
- The 3D printed enclosure works, however I have to print multiple pieces (4) to make the enclosure, and it doesn’t look that good. So I built a vacuum forming table and just this morning bought some ABS sheets. The mold is ready. I plan to try vacuum forming later today.
- The VESC (from @torqueboards) continues to go strong. I raised the default motor amperage to 50, and it works really well. I have connected an ESP8266 to the UART port to connect to it via wifi and without having to remove the enclosure, however I can’t connect to it yet. No answers from the VESC forum either…not sure when this will work.
- I designed and printed a piece to protect the motor from small rocks/dust/sand. I unfortunately got one dimension wrong so I had to melt it a bit to fit…still it works but I’ll print one with the right dimensions
- Ordered 1 more 3s battery to make a 9s system. It will fit just fine in my new enclosure.
- Need to make the routed wires be flush with the top of the deck, then apply grip tape to make it stealth…maybe I’ll need to retouch the routed channel so that there’s nothing bulging up.
- Haven’t tried FOC but it’s tempting!
Lot’s of work ahead!
Leo
