Hey so Iâve had 3 antisparks blow up on me In a row all within 4 days of ussage on each, and one blew when I plugged my batt in.
By blew I mean they wonât turn off.
And yes I did use the search bar but people just get to techchinal and my brain blows up.
Not gonna name names except for 2 of em, flipsky, lunacycle
My question is just God damn fu*"kin recommend me a good antispark thatâs compact godamit that wonât blow within a month, except for a loopkey.
@b264
This is the reason why people use prebuilt esc and not vesc.
Get the one that LHB uses Fliers 300a
The Luna cycle is actually a filer 120
It didnât blow Durning a ride but actually just sitting around
Nope seen them blow after a few months
Canât wait for my two unityâs to come inâŚ
Whats so bad about a loop key?
Eh. Nothing that bad, I just donât have a Dremel to cut a square and I arleady have two holes in my @psychotiller enclosure.
If you have a round hole and some space you can do a door knob style loopkey but its probably more effort than filing a square hole
I want my build to look clean.
Donât wanna use a house key to start a skateboard?
Nope not espically when I have to use a tile to find my keys and still use 20 min searching
Oof⌠mornings must be rough when youâre in a hurrry
I got one for secret santa this past year and its still holding up. Not sure where its from. Maybe ask @Grozniy who my santa was.
Single 6374 on a 8s3p lipo, focbox @ 40a, 16/36 on 100mm
Surfer
14
Is not the cheapest but, I hope itâs the last I have to buy, at least for this build:
Is from a member of the forum, oh yes EU
Get the Fatboy. By design it should never break like the others do.
b264
16
I explained why they fail and that you probably shouldnât use them at all right now
Unless you get one with a precharge circuit
Does this failure mode apply to the fat boy too? I thought the resistor saves the mosfets?
Nope, they are one of the only put ones that have precharge.
b264
19
No; they are the only one I know of that has a precharge circuit, circled here in red.
That does the same thing as the green stripe and resistor on a loop key.
Deckoz
20
does noone search?..
as150 mounted, look at my evo. it wont fail, and i wonât loose it.
