Looking for input and ideas as to what might be causing this issue.
I burned a DRV after overheating a Jacob’s hubs motor. I replaced the DRV and now there are no faults registering but I’m unable to control the VESC with the remote.
When viewing the remote input under the ppm tab it just stays at 50%. I’m also unable to control it via the CAN bus where it says no response from hardware.
Any ideas?
I’ve noted that the motor detection works and I’m able to control the motor via the arrow keys, I just can’t control it via the remote or the master VESC.
I’ve also verified the remote/receiver is working since when I plug it into the other vesc it works just fine.
Thanks for your response. I have tried rebinding the remote. This is a dual VESC set up. The remote works just fine on the 1st vesc, but when I plug the receiver into the 2nd vesc it does nothing. I know it’s not settings related as I’ve copied the settings on the 1st VESC to the 2nd.
Pretty confident it’s hardware or firmware related.
I’m hoping one of the VESC gurus, maybe @chaka can point me in the right direction in terms of board components to test or replace.
Ah, are your ppm settings exactly the same on both vescs?
I believe that on the master vesc (controller ID assigned is usually 0) you’re supposed to have “send status over can” unticked
And for the slave vesc, it is usually ticked.
I may be going down the wrong path, but I just want to help how I can
That’s correct Luke, send status over can was checked for the slave and not for the master when I was trying to drive the VESC via CAN. I also tried to drive the VESC via PPM control and ensured the PPM was selected under the application tab as well.
