Hi there! I have run into a problem due to some oversight on my part when building my battery pack. The nickel strip I have welded onto the pack cannot support the current i need (I was sure i looked it up before but i guess not) so I have decided to remove and replace it. My question is about the removal process, I’m planning on doing what i did when welding the battery but in reverse. So I’ll cut the series connections between the paralell groups first, so I can work with the smaller 3p groups and then when they are seperated I’ll cut the connections between the paralell cells and finally pry the strips off of the individual cells.
Cutting the series connections:
Does this seem reasonable and is there something I should keep in mind besides the obvious safety precautions like glasses and somewhere to dispose of cells incase they short out?
I’ve been searching for specifics about this on various forums but I can’t seem to find anything so I figured I’d make a post here.
