Hello, I bought crank fat cones and barrels from riptide thinking they would work perfectly… not so much. The kingpin isnt long enough to get both bushings in and screw the nut on
Could this be solved by getting 2 longer kingpins? Or should I just buy more bushings to fit
Your changing the degree of truck if you go with thicker bushings. Its totally up to you what you do though. Either right size bushings or longer kingpin.
