I am going to mount my motors in the rear, so outside of the board.
Default SK3 cables are just phase windings and they are quite hard to bend, so I presume they would eventually snap, not necessarily all of it, but some windings over time from steering movements, vibrations, etc.
What would be a better idea:
Cut the phases, leaving only 3-4cm, soldering flexible silicone wire to that.
or
Just adding bullet adapters with flexible wiring in between motors and the controller after somehow fixing the phases stationary?
Bullets works too I have done both, but I prefer the full silicone as it’s a lot more flexible and the full length bends equally. Either is fine really
The windings still have the laquer on them all the way until the end where their banana plugs are soldered.
You have a few options to remove it. Some kind of solvent would be best. You can send them (each strand, individually). Or you can melt it away by repeatedly trying to solder it and hopefully make good contact. I don’t recommend the last option despite it working well enough for me.
Thanks for all the suggestions guys! I will for sure go with the flexible silicone wire route. Yet I think it will void the heck of my warranty… I will coat my windings so I guess that’s the least of my “voiding” issue.
Maybe some of you who have taken SK3s apart, know how to properly deal with the 4 tiny screws on the can? 3 unscrewed no problem, 1 is quite damaged but I am glad it did unscrew… They seem to be screwed as hard as it gets and not damaging them is like 50/50 chance.
They have Loctite on them you can tell by either a blue or white residue on the screw. You must heat them up before unscrewing. Make sure to replace the damaged one now
