I bought a Bajaboard in a used condition of 250km. Those 250km are real and It was driven in a time of just 2 months. Of course there is a chance of having bought a board which was not in good hands, but the preowner made a good impression on me. So no reason to think about that too much.
battery, bms and cables under battery loose inside of board, terrible cable management-> improving cable mangement and building a covered mount for bms
old version of drive shaft constant velocity joint rubber boots fall of from driveshaft joint because of no possibility to fix them in position (the three small ones in the following picture) -> new version now has a possibility to use a zip tie
one controller did not work-> got a new one from bajaboard because of warranty, but the new one had a loosen Pin in one of the connectors-> quality control improvements
ball joints are worn out too quick -> using higher quality
screws of ball joints under journals got loose, because of bad (white) glue put on them -> using higher quality thread locker
too much play between plastic wheel and 5 edge mount-> higher material quality and production tolerances
Here is a video of the worn out parts:
Other impressions:
controllerdisplay not bright enough -> using brighter LEDs for display
real range of the board when driving mixed is 20km, not 30km. When reaching 35% battery status, no more high power available
breaking when roling down a mountain, when board was standing still for some seconds before, sometimes does not work, thats very dangerous!
lights donĀ“t light you the way, they are just for beeing seen by others
acceleration the first meters is boring, just after reaching some speed, acceleration is fun
hand controller is great itself, except from the display
going uphill never made problems
when board is adjusted to a small turining radius and soft dampers-> dont drive over 40km/h because of being uncontrollable by wobbeling
For normal driving the electrical differential and drift mode are the only modes that make useful sense for experienced drivers.
All the other functions like power limit, brake strength, launch control, traction control are just for beginners. I dont see any useful reason of using burnout mode.
All in all price and quality of that board donĀ“t fit together. 4500ā¬ is way too much for the bad quality you pay for.
If you are about to use the bajaboard in offroad terrain, you will be wasting lots of time in maintenence like repairing and putting money in spare parts.
On road use makes more sense for this board, but thats relatively boring.
To my mind the bajaboard GX4 2017 still is a beta tester board. For example, if you take a look at generation 3 you see better quality in suspension arms (cnc machined).
On the 2018 model front motors got smaler etc. etc.
Thanks for posting this. Iām waiting on a reply on my inquiry to see if I could purchase a Bajaboard without their battery and ESC, yet youāve confirmed a few of my suspicions. Iāll definitely pass, now. Appreciated.
I have had a board on order since march and paid a deposit with no contact now for 4 months. They have gone extremely quiet and Iām thinking issues. They have also changed the cnc parts for cast and this is a big no no for anyone who has ever had cast parts on an rc. All the bulkheads are now cast alloy and they will break.
Theres one other thing that makes it a no go for me though and its the fact that the company seems to have been bought by evolve. If you go on the website the evolve logo is on the foot. All I can see happening now is cheapo parts and bad customer service.
itās true, and I understand in China theyāre still hand-fitting the transmission parts together (meaning a replacement part might still need fine tuning)
not the end of the world, yet the last thing I need is another Leiftech
Up until 4 months ago I was getting weekly progress reports and videos from the production plant in china and everything looked legit. Now all is quiet and no replies from mails. Iāve kind of given up on it to be honest and just going to take the loss. No biggie really as Iāve changed my mind on it anyway. The board is far too complex and heavy. Rather spend the money on a decent mtb build.
Great writeup, hopefully baja can look at this objectively and improve their product because unreliability seems to be a common thread with their stuff.
yeah i had a go on one a few weeks ago. as cool as they are, they just have far too many points of failure. Also, for a āmountain boardā, once you stand on the board, 100mm of clearance really isnāt enough. Yeah they drive really well but like i said and like this post confirms, thereās just too many points of failure
seem the build quality has gotten worse, my first batch GX3 has none of those issues, I must have done 5k miles on it, I do follow the manual on maintenance - was the board ālovedā or abused before you got it? I do wonder if the original owner actually looked after this board at all.
Iāve not had any problems with the drive train at all, never needed to adjust the motors (other than to remove to fit belt - serious pain IMO)
i have to say the quality from g3 to g4 seems really badā¦ I would be very hesitant to buy a g5 model based on what Iāve seen here, thanks for the write up I think you saved me some future disappointment - Iāve tried to wreck my g3 since i was trying to justify an upgraded version (before I got into DIY) sounds like I could destroy a g4 in a couple of weeks
Crazy to hear that your board made that much miles without those issues.
The board was used, offroad and onroad. This board is called by bajaboard āoff-road beastā. So it has to last longer than 8 rides without beeing fully worn outā¦
In your case I would just change the electronics like battery and escĀ“s on your gx3 and you will have the best offroadmonsterboard.
This is Alessandro from BajaBoard.
First I would like to thank you for your detailed review and everyone else for their comments from the BajaBoard team.
We absolutely take these criticisms constructively, and in fact, between your 2017 model and the latest version, we have changed quite a few things.
Many of these we havenāt mentioned in the public arena, because they arenāt as notable as range or speed improvements, but Iāll list a few below as this is probably the most appropriate forum.
Our motor in 2017 had custom built-on motor plates. New motors are now more standard, and mount onto a separate motor plate with 4 x threadlocked screws. The 6 little screws canāt impinge on the pulley anymore, also suitable for mounting a standard 63mm motor, this motor plate also reduce the risk of the motor shaft circle clip (lock ring as you called) to come loose too.
We have been trialing the different kinds of bushings for the wishbones. This is one of the ones weāve been trialing, which looks pretty close to your suggestion.
We have already changed the pin of the outer driveshaft with one that has a slot in the middle so the grub screws can go inside the slot and hold better the pin to come loose.
Battery and BMS have been changed with a more performance and long lasting pack. Battery you have wouldāve been an 8S Li-NMC pouch cell set up. Our latest is now using Samsung 30Q, in 10S config. Right now we are also field testing with the Sanyo 20700B, which is getting good range for the 2WD version.
Cable management did leave much to be desired in 2017. In the latest model, everything is a lot tidier inside with mounting brackets to the side. We also did find that in the 2017 boards, some of the connectors could come loose because of the cable layout. Happy to say thatās all been addressed now.
The outdrive has now a slot where we can add a zip tie or retaining ring to keep the boots in place.
We changed belt suppliers to a better brand. Also going to be switching over to Kevlar reinforced belts in 2019. Also working on an underside bash plate, so the belts wonāt be fully enclosed, but they will soon be a lot more protected.
We have revamped our choice about all the joints and bearings, increasing cost on our end, and for an example, all the ball joints are made in Japan.
Range depends a lot on different factors such as terrain, temperature, weight, riding style, alignment of the wheels, pressure of the tires so itās hard to comment on your range but as first tip here is to make sure the tires are pump at 45psi. About the range of our latest boards, in addition to the change in battery, if everything is set up as it should now we can actually achieve 30km+ in real life with the G4X, and 40km+ with the G4.
We are experimenting with different headlight to improve visibility at night. Last yearās light was indeed too spread. Also the lights are now enclosed inside protective casing, insteading of being fully exposed.
I would like to add some improvements that we also made that you havenāt pointed out.
The old paint job used to chip off quite easily, changed the finish, now more resistant to scratches. And for parts that are in the spray path of the tires, like the rear wishbones, we are looking at other methods of surface overlay protection.
All the steel parts have been galvanized apart the drive shaft which is going to be protected in this year production
Improve gasket for water ingress (still not fully waterproof, but a lot better than 2017).
This isnāt a sales pitch just to be sure. Just wanted to acknowledge the criticisms. If you guys have any other suggestions, or questions, please leave them here or just email us.
Welcome Alessandro I was tempted to invite you here to respond I take it youād be up for assistanting me with advice here when I āpimp my Bajaboardā
