and a small video of the turbo engaging… it is a bit dark though, sorry
@marcoluz
I’d say put throttle switch at about 20% ?
Then, first punch put very slow, then 2nd punch maybe slow… this way it should make soft initial acceleration and more decent - less soft, mid range - end range acceleration…
I think you need to play with the numbers… try to find the sweet spot at what throttle level to switch to higher acceleration…
otherwise just leave the setting for both punch rates the same… should not feel the difference in theory, i think.
As for the turbo… if you cannot turn it off completely… i would try to set it really high… so that when you ride you dont reach the rpm needed for setting the turbo… like… if your motor max rmp is 8000 (use a calc for this)… then set turbo for 10-12 000 rpm or more… so you dont reach this number at all…
