Looking for 6mm (quarter inch) risers for MBS Matrix Pro II trucks.
For example, the set from Alien power systems look good, it would mount, but it doesn’t quite look wide enough.
Any ideas where I can source risers wide enough?
Could be reasonably easy to design and laser cut a piece of delrin if you have the dimensions of the truck. I’ve 3d printed a few risers from ninjaflex (100% infill) that work nicely as well. You’d obviously need the dimensions of the truck though.
Check out the E-Toxx website. They have wedges specifically for these trucks and I bet Jens @Nowind could make some flat risers for you.
Hey Dude
as @Mobutusan mentioned we got some TPU Wedges and Risers for the MBS MAtrix2
We got for example 5mm Risers, sold as pair
Cheers
Just ordered the r5 (5mm flat, no angle) risers from you. Thanks, looking forward to adding them to my build.
