I just found out, new metro may use vesc hardware, from vesc project forum. But since Duty cycle mode is not well supported, (brake is not as strong as current mode, no regen)
it’s deal breaker for them apparently.
I used hobby esc, I like the duty mode for controlling speed, but the brake is really weak. tho there is a trick
Watt control mode thanks to @Ackmaniac is the best way to run your motors, hands down.
The thing is if any board company comes along like this, they will likely cheap out and use shitty quality vescs and have a lot of issues. It’s not cheap to get good vescs, and that will destroy the profits of any board company like this, so they won’t do it.
Duty Cycle mode is unusable on vesc. As soon as you let go of the trigger it brakes automatically, it has no coasting. Duty mode is a feature I really miss which I think literally every other esc has whether it be for RC cars or other e-skateboards. Vesc has current mode which I guess people don’t mind.
I find it more important to have a smooth acceleration. This is why watt control mode is good. You know that for example, say max watts is 1000 per motor, at 50%, you have 500 watts, at 25%, 250 watts, or full throttle has 1000 watts. It’s easier to control than current mode and way more predictable.
Yeah, I know. But I don’t limit the watt. So I really don’t feel much different from the original fmw.
Maybe tiny bit torquy. and low end is a bit smoother.
I defiantly noticed a difference. I had more power at different points on the acceleration curve. It was unpredictable, especially at higher speeds. Watt control mode fixed that. Can you imagine doing what NVG does, 60 mph on that little throttle range with duty cycle? It’s uncontrollable.
Limiting the watts doesn’t mean you’ll necessarily hurt performance. The key is to know what you can pull safely, and set it to that. It’s another mechanism to better protect your motors too. Most motor manufacturers give data on max wattage, but not max amps.
Yeah current/watt mode is like whatever. I feel like I’m not in control with those modes. With duty it feels like there is more torque at low speeds and when there is more load like going uphills or off-road. And it’s really controllable at high speed. With watt I probably use 25% throttle and I can wiggle it and it basically does nothing lol. But I doubt Duty will make its way to the vesc as vedder doesn’t like that mode and neither does ackmaniac.
Duty cycle is very predictable tho, NGV is right direction for that speed master. They may have to careful with sudden amp spike in the beginning, but from what I experienced, duty cycle is more controllable once u used to it.
I get that current is like driving gas car,
but the duty is like setting the speed using button, which I found more predictable on fingers.
see, I feel like torque is better way of controlling than speed. When you have a 1 cm throttle range, and a top speed of 60 mph, just 41% of the throttle will give you 25 mph. 8mm of play, to go 25 mph, is crazy…
With watt control mode, when your at your cruising speed, you let off (like a car) and apply a lower current to maintain your speed. That’s the most predictable way to ride, at least for a high torque board like I ride. Duty cycle with the power I have under my feet could kill me.
no, you can let go with duty and it will coast too. I’m not sure why u referring to 1cm throttle range, but I can tell you that it’s enough range. people use chopsticks u know, with 50 muscle movement.
Duty can still work like current, since it doesn’t go full speed in 1s. it still need acceleration. It just feel jerky in the low speed, cuz it tries to use full amp.
More problem I see is the resistance in belt/hub motor in high speed.
Soon as I pass 30mph, if I let go throttle, board loose the speed rapidly. I almost fall.
@ I went up to about 47mph, higher u go less acceleration u feel, so it’s not bad.
I’ve never personally tried duty cycle above 25 mph before, but even then, It tried so hard to throw me off. This is the biggest risk we have an eboard in my mind. It’s how I messed up my ankle.
I have a metroboard as well as a diyboard,The Metroboard is a workhorse very well built
breaks are super strong i love it the lads in Metroboard build great stuff…
