Hey
Can I run my sensored motor on my sensored/sensorless ESC if I don’t connect the sensor cable? And if so, can I then connect the 3 motor cables any which way like you normally would with a sensorless motor?
Hey
Just connect without sensor and make sure you get a good push off before you accelerate. You can switch the motor wires around no problem if you go sensorless.
@popopopop I am running racestar motor x2 and 2 Vesc when I connect the sensor cable it’s loud and rough what could be the reason?
Are you using a VESC? Maybe the motor detection didn’t run well. Try running it again
