I made this simple enclosure for @Jeff Hi5ber Python so figured I’d throw it up in the marketplace. The Apone V1 is designed to house up to four Multistar High Capacity 3S 5200mAh Lipo packs, a single VESC and a standard 2.4ghz receiver. Mounting and motor holes are optional.
No it will flex to the concave. I’ve tested it on a Jet Spud deck which has a very extreme concave and its fine. I would recommend a stiff deck though.
Yup I’m working on it this week since all my parts are coming in. It will be called the Sulaco V2 with a 2 piece design, can hold Space Cell + 2 VESCS with motor holes.
In the future, I plan on getting a second set of 2x3s batteries and swapping them out once one runs low. How can I mount this case to my board and be able to hot swap them easily?
I plan on using some adjustable length clevis pins:
I should have some time over the next few days to complete my build and will post some pictures. The @RunPlayBack enclosures are stiff enough that putting a pin in each corner along with a gasket should be enough to keep everything out.
@lilracerboi let’s see what @Jeff cooks up, he’s been thinking about this for quite some time in regards to the quickest way to hot swap. @delta_19 yup I could see that working as well. There’s a bit of a compromise between making it fully weatherproof and secure and being able to pop it on and off.
I’ve tried wingnuts on my first box I had, but I still found it cumbersome. Right now, I have a small clear plastic tackle box with the insides shaved out. It closes using clips and I found that to be the most convenient way to manage my components.
Seems like it will be pretty weather proof, the adjustable pin holes allow you to get some nice compression on the gasket. I can remove the lid in probably 10 seconds.
Looking sleek and clean Jeff! Kind of reminds me of my RC Truck days when I’d have to pop off the bodyshell to access the components. Can’t wait to ride man. #A2ESK8
