| Second Build | Vanguard | Focbox | 10s Single 6355 190kv | Split Enclosure
Hi there, After reading a lot of builds, and have build a cheap board, I decided to rebuild my first diy board. I love the desing of boosted but like DIY board much more :wink: So here goes another build topic…
Specs Deck: Loaded Vanguard - Flex 2 Trucks: Caliber II 50s Wheels: 90mm ABEC Clones Enclosures: Eboosted enclosure Battery: 10s4p Li-ion 30Q VESC: Focbox Motors: 1x 6355 190kv Motor Mounts: Hobbyking Remote: Nano-x Bluetooth: HM-10
I want to know if it is possible to route those wires such as @whitepony I don’t want a broken board over time :sweat_smile:
image image
as you can see from the picture, i laminated the routed areas with a layer of fiberglas to be safe! using the board since 3 years nearly daily now (around 20km/day), never failed me yet after using nowinds extreme ronin mount!
I have done this too, without the fiberglass even. It works great, never had a problem!
Also the motor wires?
I think i don’t want to work with fiberglass it is much work I think. I don’t have experience with it…
Received my enclosures from @Eboosted They look great! Thnx for it!
Now i am thinking about the battery config. 10s3pimage
:heart_eyes:
That BMS is huge!
I know… is 60amp con. maybe thinking of 80A but that is to high for the cells. I have much space under the BMS and don’t know to do something with it
Why don’t you use a BMS for charging only and install a 10s4p?
how deep did you route the board for the wires? PICS PLS
I don’t trust myself with discharging. I want to have a BMS that check each groups off cells voltage. And off the weight. I have a 10s4p pack and don’t want to till that weight when walking.
I am also building a pack that can do charging while driving. So if I want a large range, I can take that with me
@Eboosted I saw that you are using a 10s4p pack in your build. Does your housing fit perfectly on your board? When I insert my 10s4p pack into the housing, the housing rises a few millimeters imageimageimage
When i place my 10s3p pack in the enclosure, I have the same problem :confused: imageimage imageimage
It seems the issue is the Flex 2, the flex 3 has just a small gap that closes with the bolts. Try fitting the 10s3p and install the securing screws.
