I am building a flexible battery to fit inside a @Kaly segmented enclosure and im trying to work out the best way to securely mount the cells.
My plan was to make neoprene / EPDM sheet that would fold up around each parallel group.
When folded this would protect against vibration.
Additionally I expect that once they are all packed in together it would add extra isolation to prevent shorts between cell groups. Looks like these should fit sungley inside the Kaly enclosure but will still allow small amounts of movement if needed.
BUT THEN I DECIDED TO SEE HOW @Kaly DOES IT . . . After some detective work i found a few images of inside his boards.
Looks like hes spadged the cells into place with some type of glue or silicone
Now im not sure what to do . . . .
It seems that gluing them in place does reduce the risk of them ever moving and would reduce strain on connecting cables however i cant imagine that it offers much in the way of protecting against vibration. One thing i don’t want is anything that can rattle whilst riding.
How do you guys mount your cells in flexible enclosures?
Do you have any positive or negative experiences using either if the methods i mentioned above?
