I’m selling 45 new 26650 liitokala batteries:
Capacity: 5000mAhMax continues current: 25ADiameter 27mmLength: 65mmWeight: 95g
I have a spotwelder and parts laying here to make a complete 10S battery pack as you can see in the pictures.
So if someone is intrested in buying a battery pack.
I’m not able to use them because they took a month to arrive and in the meantime I had already bought other sells which arrived faster to make my esk8 and use it the summer.
Some possibilities:
10S2P with/without bypassed bms
10S4P with/without bypassed bms
12S2P without bms
12S3P without bms
A 10S2P 10Ah battery would be perfect if you want to build a board with the ownboard/wowgo kit and you wish you had more range than stock the batteries they are selling.
These are no fake cells, I tested them and they perform like they should. Lygte has a full review about a ton of cells!
Here’s a comparison between 30Q - Sanyo - Littokala:
Some other pics because people like pictures:
For prices It depends on the cell configuration.
(For example, I would ask 150€ for a 10S2P with bms)
This is my 4th esk8 which is using the ownboard esc and motors, love the board and it’s pretty affortable (500€)
I have used these in my last 2 builds the only down side after 40 or so Cycles the range seams to diminish a lot more than say Samsungs, the current capacity is awesome and the 18mm to 26mm width is easily compensated for.
12S3P 15000Mah bestech charge only BMS powering 2 x 6.6 flipsky esc’s ( cells were bought during black friday sale 40 cells for $160) value for money is awesome and range is still awesome. Current limit I have set at 60amps. Sadly the seller no longer ships to Australia
