In your description you say it has a push button, hold button, a place for a fuse… I’m just trying to figure out where these are supposed to hook up now. Obviously the power input and output needs no explanation, but I’m not sure about the rest is all. Thanks for your help this looks fantastic!
Yes I realize that, but the PCB still has what looks like that connector thing that is in the renderings, except it’s not on there… So I’m just curious what we need to do to connect an on/off switch, where the fuse would go, all that stuff, cause all I see currently is just the input and output.
GND means “Ground” or negative and BTN means “button” (momentary-style) and LED means Light-Emitting-Diode and you’d need a resistor for current-limiting depending on what LED you use. The LED port is optional.
I am sorry but this product is for higher technical level, not made for beginners, if you dont know where to plug fuse I would not suggest to use this device as the currents that high can kill you. I would suggest to learn basics of electronics first to understand how this device works where to connect it and what potential dangers are.
No I see the problem, I am on my phone so I couldn’t read what it said in that corner, but I just looked on my computer and see it so nvm I figured it out. Thank you!
The point is that this is experimental hardware using enough power to stop your heart. So you need at least a novice understanding before you start working with it.
The switch goes right here…
Which anyone with a novice understanding of electronics and high-amperage switching systems would know.
Yes I can see that now. I just wasn’t able to read it at first cause I was on my phone. After looking at it from the computer I am fine, all questions answered.
… And with that in mind, and the fact that @Kug3lis doesn’t actually require you to have an “electronics license” to get one of these “higher technical level” switches, a slightly more accomodating response would not have been considered out of place imho
@Kug3lis is it possible to have a revision on the dual finned focbox cases to include this Fatboy antispark? Maybe right in the middle so we can take advantage of the active air cooling.
@Kug3lis any changes that you could make your dual housing for focbox, like the one for the Escapes, so it could be mountet inside an enclosure, and stil have greate cooling via the fins… I never got, why you want your dual enclosure to be a separate thing, with lot of wiring harness between the dual enclosure and all the other components?
