Hello everyone, Im selling my board, I build on 2019 I did many km. Im living in Netherlands and I’m selling for 290 (negotiable)
2P10S the batteries Samsung INR18650-20R 2000mAh - 22A
motor Turnigy Aerodrive SK3 - 5055-280KV Brushless Outrunner Motor specs motor: Specs. Turns: 18T Voltage: 6~10S Lipoly RPM/V: 280KV Internal resistance: 0.031 Ohm Max Loading: 60A Max Power: 1510W Shaft Dia: 6.0mm Bolt holes: 25mm Bolt thread: M4 Weight: 369g Motor Plug: 4mm Bullet Connector
VESC Turnigy SK8-ESC V4.12 For Electric Skateboard Conversion W/BEC you can aset up all the definition from VESC
The BMS have all the safetys requireds, cut off, balance charge, balance discharge, sensor temp. …
I have a enclose for the batterys and VESc and BMS like Boosted board
What need to be update/replace: shaft from the motor, but I will advice to buy a Hub wheel is better.
In the enclosure looks like the surface is melted but actually is a rober tape, (is flexible and still glue) is to create a water prof for the battery, the screws is to hold.
But here some pictures.
now the skate have scratch, the rest is good
