Sensor short by water... Thought?
So, I just went past the water puddle. my board is watertight, like pressure watertight. except motors. my torq motor used with water before, but this time I connected sensor cuz I have it why not use it right?
now it shorted and took my focbox with it. Prob DRV death. (there goes my lunch money FML)
I’m going back to sensorless. trying to mess up with startup boost, I usually do 0.04 but thinking increase to 0.05 or 6 for better stand start
what u gys think?
Any input is appriciated.
To me I would think that it would short at the plug on the focbox. I would not think that the sensor would short in the motor
I had this happen 3 times. The solution is to take the motor apart and put silicone conformal coating on the sensors and all the electrical connections inside the motor.
I was thinking maybe there was some not-coated area on sensor on motor. @b264 thought the something but I guess no going back at this point I prob killed the sensor already. I trusted too much of this company to do right QC. (No offense, shits happen. it’s the factory that makes this after all)
yeah possibly but you could take the motor apart and coat everything like @b264 suggested and see if it comes back
TBH I don’t know if the sensor is still shorted or not. I don’t want to risk another drv tho. unless u know how to check it…
I have seen shorts caused by bridges created between solder joints in your case I would think this bridge would be water. Does the motor still work?
I haven’t check it. focbox is dead so can’t confirm rn but I will take apart the motor. I will take a look the solder on the sensors Tnx
I think if you apply ground and 5V to the sensor board you should see the lines going near 0V and near 5V as you turn the rotor
So I check line btw 5v and ground and turn motor with multimeter?
Turn the rotor with your hand
srry i ment turn motor with hands, and use multi meter to detect voltage. turn with multimeter sounds really stupid haha XD
There should be 5 or 6 wires
Ground, Power, A,B, C
or
Ground, Power, A, B, C, Temp
You’ll have to figure out what they are. Red is generally a color used for +5V and black is generally a color used for ground but you’ll have to trace them back to the ESC and see which is which
Ground and Power need 5V or 3.3V and then A, B, and C should alternate between true and false (on and off / high and low / 0V and 5V) as you turn the rotor
I opened my board. Sensor is fine but focbox blew L damn… @JohnnyMeduse do u think u can fix it or toss… 20180731_150855
Hmm you blew a direct fet, you can try to repair it but it depends how bad the PCB is damaged. Worst case they say it can’t be repaired and it gets tossed anyway so why not try.
Sorry the PCB is completely damage, there is not really a safe way to repair it.
Just curious, would it be worth it/ do you recommend saving this board to use as spare parts for his next fox box?
Well I don’t plan to buy focbox anymore as there are more option now including the new unity. I’m just ganna wait for next Gen vesc. At 12s, power isn’t an issue…
But yeah if anyone wanna buy this focbox I’ll sell it really cheap
I guess I was mostly interested in if it would be worthwhile in general. I do industrial automation and have rebuilt a few drives in place do to lack of spares etc. also I’ve read there is a direct fet shortage.
Oscope so cool for this
IMG_20171029_221924
But so far hall sensors have given me lots of pain and not that much gain. No mas for me.
EDIT btw i never got bldc mode sensor detection to work on that motor. Tried every permutation of phase wires too. Grr!!!
