So I bought this motor from diy electric skateboard and this esc from amazon, both sensorless/sensored compatible. I hooked it up in the sensorless configuration and it worked fine, but I’m confused on how to hook it up in the sensored configuration.
The instructions for the motor says to make sure the ABC motor wires are hooked up correctly to that on the ESC, but the colors are different and they don’t say what is what (yellow, blue, and black on the motor… blue, yellow and orange on the ESC).
The motor has a ribbon cable that corresponds to a port on the ESC but there is only one way to plug it in. So does the order of the motor phase wires matter in the sensored configuration or can I simply plug in the ribbon cable from the motor to the ESC and it’ll function as sensored fine? Thanks in advance!
