MOTION-SPIN Uphill Test
awesome
Looks great @secupol. Looking forward to seeing another esc option in the wild. Will you be performing more tests before producing some for sale?
The firmware is updated latest 3.50
MOTION-SPIN Dual
□ AUIRF7749L2TR Automotive Grade
□ DRV8323RS Smart Gate Driver
□ Firmware : 3.50
□ VESC Tool 1.04
□ Size : 99.6(W) x 84.0(L) x 17.0(H) mm
□ VESC 6 Clone x 2
[VESC Tool BLE Dongle]
Main Module : BGM111 (Silabs)
VESC Tool Mobile app compatable
VESC Configuation
VESC Monitoring
Looks Awesome! Two small and easily implemented suggestions:
1 - Please put some silicon around the caps to hold them in place otherwise they will break off 2 - Please change to USB type-C
Thank you for a good idea.
What is the price for the dual?
I sent a message.
can you give us the specs? like max Volt ect.
Only gate driver is different from vesc 6. Therefore, almost all of them have similar specifications.
Hi there Is there any feedback from these really wan to buy them if they actually work and are they 12s? I see gate voltage is 60v? Thanks
great job bro! I also designed a vesc6 which has 12 mosfets and uses drv8323 as gate driver. The size is a little bit smaller 40x70x20mm. I tested under 42v 1000w. Just works fine.
FOC Sensorless Start-up Test VESC based HFI Vs Instaspin based from TI’s Chip
Hi !
So I’am not sure how to interpret, the sensorless FOC startup with the TI chip is smoother ?
