Hey guys,
Ive got a 12sbms charge/discharge without e switch now so I have a extra switch from @Martinsp . Should work fine but Iam wondering about the order for the modules. We think it doesent really make a difference, I was just wondering if the bms draws current from the battery somehow if I cant ride for a week orso. Maybe there are other problems I wasnt thinking about.
Maybe a silly question but I dont want to do sth wrong
So Vesc, switch, bms, lipo
or
Vesc, bms, switch, lipo
Thaaaanks
Thanks man, I still have the loopkey left. I would assume to put it at the p wire from vesc to the switch? You think thats ok?
No
Are you using an anti spark button switch and a loop key or just a loop key?
If just the loop key use one wire, if the button switch attach - to - and + to +
no I want to add a loop key to the whole system what already has a on off switch just in case sth fails. I was just wondering if it makes a difference where I put the loop key
ok I found a threat should search more
No not really. As long as itβs in between the Vesc and battery. Although sometimes I have seen anti spark buttons leech off the battery so it would be best to put it between the anti spark and battery
