First I’d like to thank everyone here for helping me so much with my first eSk8 build.
My board is set up with dual Torque Boards 6355 motors which come with Hall Sensor wires. However, the site I bought them from has this statement: “Motor can be used with or without a sensor. Sensorless operation is most common.” I’ve been ridding my board without the Hall Sensor wires hooked up for about a month now and I keep wondering if I should have bought the correct adapter to connect the sensors to my VESC.
I’ve done some research on what Hall Sensors are and it seems like something that would be good, but I keep coming back to that statement that says sensorless is the most common way to run the motors. Any info to help me decide if I should run with or without sensors would be great.
You could run it in Hybrid mode with the VESC this will allow the motor to utilize the hall sensors at lower erpms for slow starts but then it shuts off at a predeterrmined ermp. It’s usually the most efficient this way.
Edit: I run mine on hybrid and it works like a dream. I can come to a complete stop on a hill and there’s no stuttering at high speeds
So far it sounds like it’s better to run with Hall Sensors. I’m just confused as to why the site I bought them from says the motors are normally run sensorless.
Some ESCs might not have sensor wire connectors. That description was written quite a while ago, things have changed a lot. I’m pretty sure there are 0 downsides to using Hall sensors if your motor has them.
