Some of you may have seen my post regarding acquiring cheap Mini Fiik’s in the UK. These are Single 75kv hub boards, presumably with some weak ass battery and a basic chinese ESC.
I have absolutely zero experience with hubs, so I’m trying to decipher how they work.
Now I had the idea last night to get two, and just for the giggles rig it into a dual hub board. Im assuming the hub is connected to the truck in some way shape or form, and as such i’d have to put them in a diagonal drive?
I’d obviously need to replace the ESC’s with two vesc’s too, and have them using one receiver.
Is this even remotely possible? What would the maximum(ish) amps these hubs would be able to handle? I’m really struggling to find any specifications about these boards whatsoever, so I’m not too sure on them.
Any insight on the mechanics of this would be great, as im tempted to even just replace the battery and/or esc to speed things up a bit.
I dont see any reason why diagonal hubs wouldn’t work, never seen it before though people do diagonal geared builds so I think it would work fine. Not sure what size wheels those are so I cant say much but with my 90mm Maytech Hubs I have max amps at 50 and they usually steady out to about 15A and only spike that high when accelerating.
I built a dual diagnal Carvon V2 hub board. Worst handling board Ive ever made. The board got dissassembled within a week and converted to a dual rear. The only way I can imagine this would be ok is if the board is very underpowered. Otherwise the torquesteer/truck walk is unbearable and puts you into a speed wobble when going from acceleration to braking
Ah okay, interesting. Pardon my ignorance, but am i able to simply have two single hubs, pop one off and pop it onto the one truck to make it a dual drive? Didn’t think that would be possible
Check out my review of them HERE and to purchase them, I emailed them though you can get them on AliExpress as well. $90 a hub and you need a special type of truck to fit them as well which is $25 as well. So far there great hubs though problem is that at 6S I’m only getting upto 20mph max which sucks compared to the 32mph on my single Carvon V2. Though I think 10 or 12S you’d definitely get more speed.
I’m not sure about the changing the hubs out for different truck but you may be able to. Try taking them apart and see how far you can get.
Is that for both hubs? I’m wondering if the cooling of stators wouldn’t be a problem, could I set the VESC amp rating to higher than 22A per hub? 65kv 90mm ones at 10s with FOC
I believe the Ackmaniac firmware does total your current draw for each VESC when you tell it you have two VESC’s, which I did, so I believe yes that is total current draw. While my motors did get warm they stayed under 60c from what I remember which is totally acceptable, so I don’t think throttling to 22A max is necessary or wanted because it will diminishe your acceleration.
