I think you run the risk of pulling to many amps with 6s vs 9s. Its up to you, you might be fine but I personally would wait for my other battery to come in. Just my opinion.
Too many amps through vesc is necessary to achieve the same power as if the voltage were zincreased and you’ll likely hit a temp shutdown.
So must run Not as much power. Lowered speed. But if ur esc can do more amps and u run more amps the motor can perform as wel…with as much power
Ur “battery amp” limit is what determines the heat in the vesc
Still don’t know what the max amp limit setting really does.
In theory the vesc will shut down if it gets too hot as set in max temp setting so u could experiment with maybe running higher amps an see how it does. Maybe decrease the temp cutoff if u feel safer. I like 70amps battery and also have motor amps set to 70 and have never had a temp shutdown on 12s. but it’s seeming u can up the Motor amps to its 200 max. That’ll get u faster accelerations and With the pmw(way the esc works) it would be 200 for fractions of a second, at slower speeds, and still average the 70 battery max setting if that’s what it’s set to. How bout do 90 and 200 and tell us how it goes on 6s!? Add a big heatsink
I will try it when I have the VESC’s ready then
But you cant really do much with a heatsink on a VESC 4.12… the FETs used are dissipating heat into the PCB, and its trapped there due to the bad thermal design of the VESC
I thought about changing the layout before ordering my pcb’s, so the FETs were on the same side, and then add heat-sink, but time wasn’t there to it
