I am building a longboard with a single 6374 motor and plan to add a second when I get the money. Is it possible to run a single motor on a dual motor esc such as this one:
yes, it should work. read some more here:
but just to warn you, this is probably oldest of all cheap chinese esc. you will be better to buy newer esc from wowgo/meepo/ownboard, braking is much much smoother
Thanks Ill have a look at a newer esc.
Yes, I’m using a Wowgo 2s dual hub ESC running a single hub build for my daughter…
