While taking into account that i have a 66T wheel pully, 15t motor pully, 7 inch tyres and Space Pro 3, what speed would I get with a single Turnigy Aerodrive SK3 - 6374-149kv motor compared to a dual setup? How would it manage hills compared to a dual? If need be, how do I make the single faster?
you can also get the sk3 190kv from hobbyking, they have a UK warehouse, but keep in mind that these motors need a few modifications before you can use them in a build
or the 6355 190kv from alienpowersystem based in the UK
If you are very knowledgeable about motors and you know how to make adapters and modifications to suit your needs, then I guess you could go with that one…
I only recommended the ones I know people use in this sport
Do you already have the components listed? If so, the easiest (reed: cheapest) way to make it faster would to increase the size of the motor pulley, at the expense of less torque
What alternative is there to the space cell?
Edit- Oh, are you talking about the 7000 wt motor? I’ve already decided to go with the 190kv from alienpowersystem
