At first I think I will just drag the bag and cart around by hand behind but will look at hitching something removable on the back of the deck to tow the bag and cart.
I will need a park brake too, I’m not sure if you can have an electric park brake through the motor controller? or I need to jig some physical brake incorporated into the hitch attachment I can just use a foot to lock on or off when I need to move.
You might be able to use a brake light for a drone depending on the remote you are using. If it has a 2nd channel you might be able to rig that up so it will turn on the brake light, there was a thread on this but I can’t remember what it was called
ahh sorry I misread that maybe, have a relay switch connected to channel 2 on the remote and have the relay short two of the motors phase wires, which will cause it to be very hard to move but not impossible
Of-course I would be parking on hills… why would I need a park brake if I was stopping flat level ground. A mountain board setup is not needed for a park brake.
Ok I though you would have had to have a pretty strong brake so the board doesn’t get pulled down the hill by the weight of the bag and cart although you said you haven’t done that yet but it might be better to kinda over engineer it so then if you do it won’t be pulled by the cart
Not a lot of force is need to hold it at a stationary position if you are already stationary even on the steepest hills, bag and cart be no more than 20kg but like you said I haven’t got to the practical testing of any ideas for it yet and won’t for some time,
No I do not want to argue. I was trying to help you to solve an issue that you might have trouble with. The last thing I would say you could do is put a rubber band on the remote and wrap it around the remote trigger so it pulls it to full brake when you want to. I will stop posting now as my help is not wanted, good day and good luck with your board
Dare I suggest it – and this is not a joke – you could throw an anchor overboard. Seriously, you could put a loop of string hanging off your backpack and just wrap it around the truck
