Yes, you read the title right. My motor shaft is skipping.
I was wondering how could I re-tighten the shaft to the can because I cannot get the two grub screws at the can end loose. I think they might be friction welded to the can or something by now. Even if I manage to remove them, how could I fixate the shaft in the bell again so that it doesnât chew through the grub screws?
Get a heat gun heat the screw up for some minutes. Like this you can get them out.
They just fixed with loctite at the moment.
When you fix everything together use green loctite. That should hold everything in place for ages
Take apart the can from the stator. Than try to heat only the grub screw.
You will not get it lose without heat.
I got mine lose with about 200degree heat on my aps motor without issues for the magnets.
sounds like its a goner that motor dude. Seriously if the shaft is slipping then nothing but a complete strip down will fix it and if the set screws are that damaged then not sure what you can do about it be honest.
Try heat and donât worry about damaging the magnets because what choice do you have? try to get it apart and check out the issue.
Maybe you know how I can remove the shaft without full disassembly of the stator/rotor? It seems like the shaft slipped out a bit for me, so maybe I can just hammer it out when I remove the screws and circlip? Or should I really just take it all apart because of a bearing or sth down inside? I am afraid I might break the 4 screws that hold the âfanâ assembly on the big bearing.
bore the old screw out and make a new hole and thread for a new grub screw.
if you remove the shaft and not the bell, nothing is left to hold the bell in place and it will stick to your stator and inserting a new shaft will be a pita because bell isnât center anymore
(edit: i forget sk3 do have additional support bearing, could be less pita then)
I will just see what is up in some time and report back. Maybe replacing the grubs will be enough, maybe I will need a new shaft. I will see. Thanks for all the proposals, see you soon!
