lots of flux mate, lots of flux.
The multistar 12000 is only 2c. Too bad. The 10000mah though great deal. At 10c and 10000mah that’s great. If u didn’t have a job u could probably sell soldered packs of those.
I have ordered some of that blue shrink wrap from ebay too, so it will look like a professional product when I’m finished.
@lowGuido, Thinking about ordering 2 of these from HK since they are on sale for $50 USD ea. Did you do this to both packs?
Yeah man I did both packs. Except on the other pack I put the balance leads out the -ve side so when I stack themi have the balance leads on the same side of the board.
10 posts were merged into an existing topic: Low Guido’s hack board. For Science | now with push assist
So after a lot of consideration about pros and cons of carbon fibre I have decided to make a maple carbon fibre hybrid deck.
I plan on putting another layer of carbon on the bottom too.
That is so awesome, i was planning on doing the same thing only with a space cell in there. How many layers of carbon fibre did you use? And did you test the strength already? I thought about reinforcing the board by adding small alluminium bars/strips if the flex is to much.
there is 2 layers on the top and I plan to put 2 layers on the bottom as well. I stood on it today and it takes my weight but I plan to strengthen it with more carbon anyway. I have also thought about the possibility of aluminium strips, but I don’t think it will be necessary.
That looks awesome, man! It looks quite thin. Are you going to be able to service the components once you apply the bottom layers of carbon fiber?
I intend to be able to open it up and service if necessary. I have a plan. I’m just not sure what it is yet…
That’s awesome! For your access lid, I could envision a hinged lid or two (for battery and electronics) held down by clevis pins, like a race car. There would be a small 1/4" step down in the wood around the perimeter of the enclosure and the carbon would wrap down and cover that step, stopping at the inside edge of the enclosure. Then, on that step would be a thin layer of rubber or neoprene gasket material that the lid would seal against, with pins to hold it in place. The bottom would basically look like flat carbon with a flushed, hinged hatch that would be mostly waterproof. I don’t know if that makes sense, but that’s what I would try if I had your skills.
I would remove all jst plugs from the vesc, then also solder a external USB jack and imbed it into the wood, then I would ask some one for confirmation but Iv been running 2 VESC off of 1 cap pcb as I’m limiting both vesc to do less then some are running on 1.
I’d like to keep both my cap boards. in fact fitting the VESC’s isnt really an issue I allowed space for them. the things I haven’t yet allowed for is lipo alarms. (of I suppose I could just rely on the VESC low voltage cut. thats probably easier) the beauty of having wood in the build is that I can just route out holes where I need to. I’m thinking about having a loop key somewhere behind the front truck…
I love this, this was my first inclination when I stared looking into esk8
How did you apply the CF without it caving into the hole? Did you use a vacume press I’d love to see a video of your process
so the carbon fibre topsheet was first vacuum formed over the top of the deck and then laminated to the top of the deck once the deck had been cut out. I also intend to vacuum form some more sheets of carbon over the bottom of the board once I have routed out all the voids I need for wires and whatnot. I trimmed the hole a little bit too precisely so I’m going to need to route out approximately the width of 2 sheets of carbon fibre so that when I do the bottom layers the batteries still fit.
My original plan was to make the board entirely from carbon fibre, but I’m hoping the maple will help to absorb some of the reverberations of a stiff full carbon deck.
good call my one dislike about a full carbon deck!
