Hey everyone,
After doing some more research, I’ve settled on the following parts for my first build. I already have 2x 6s 5000mAh Zippy Compact, a Tacon Big Foot 160 245kv motor, and a charger so that saves some money. I wanted something a little cheaper/shorter/more unique than your typical eboard to use at college. I found comsa42’s Instructable and was inspired:
Battery Level LCD and stickers for sticker bomb for $10 shipped from aliexpress.com
Motor mount, pulleys, and electronics enclosure will be 3D printed
Drew it up on Solidworks. Everything is to scale. (I only modeled the electronics box, the motor, and a quick mount for concept. The rest I found on grabcad.com to save time):
Might have to cut the board like this if there’s wheel bite:
Will be updating with progress. Thanks for looking!
That esc is rated at 10s max. Did someone test it with 12s? If you go 10 or 12s, that motor will hit erpm limit and ESC might bip always and not work. I would recommend going 6s or getting a <200kv motor.
Edit: also u might not have enough torque with high kv
I have run a v1 esc on 12s. Tourque improvement, but hardly any top end boost. I think it’s properly limited. Just give it good cooling as it gets slightly warmer than 10s.
I’ll be using 6s so I can use the motor and batteries I already have (my dad used to fly rc planes and had them sitting around). If I like it enough I’ll upgrade. Also, you have to choose between 6s, 8s, or 10s when you order. Are the boards actually different from each other? I’d like to be able to upgrade to 10s later down the road
