Hello! this is my first board build and first post. I’ve been researching for months and finally finished my board today. After my test ride I cant get above 12 -13 MPH. I think i should be getting at least 20 -25 MPH. Maybe some of you have ideas about my slow speed? When i go full throttle it hits around 12 MPH and i can hear the motor cut out. Maybe the ESC is limiting my speed?
Here is my set up:
Riviera longboard deck
MBOARDS extended trucks
Kegel Orangatang 80mm wheels
MBOARDS dual motor ESC for 10s battery
Battery 10s3p LI ion
Dual Flipsky 6354 190KV 2450W motors
DIYE Motor mounts
Boardnamics wheel pulley and belts.15 t motor pully / 36 wheel pulley
Its was around 60% when I tested it. I guess i seen a lot of people with the same ESC and motors and don’t have the same speed issues. Im about 750 bucks into this thing and i really don’t want to keep dumping money, Oh well.
Update-Apparently Mboards ESC come In some kind of beginner mode so that was a main reason why I couldn’t get over 13 miles an hour. I turn that mode off and got the full power mode. I got up to Just shy of 20 today so a bit better. With my gearing and wheels and battery esk8 calculator says I should be getting around 22 so I’m pretty close
