Rage.
Hoping someone can tell me what I did wrong.
Or tell me it’s fixable…
Sequence of events…
I just got finished running a motor detection on my 6374 and got the hall sensors working (another storey but it’s fine)
Turned everything off. Plugged the canbus cable back in, (other focbox was already configured, set as the slave and all G … I had previously had everything running)
Plugged in. Throttled up. Perfect. Motors in sync, no cogging (previously mentioned storey), lookin sexy as fuck.
Power up again, then gave it a bit of brake. And then smoke… (From the master)
Other deets
All the other focbox settings were default I didn’t mess with anything 99% sure on that.
12s5p 30q battery. Charged to about 46v.
the slave focbox still worked / other motor spun. (While still connected to the master even though it wasn’t working)
off an on again - nothin. Just sits there with the blue light.
Anyone know what’s fried looking at these pics?
I’d never opened it up so I can’t spot the difference… (Also not that electronically savvy)
Needless to say … I’m pretty bummed. Been putting this together for about 10 months and it’s my first build.
Taking it back out of its case… It does ‘smell’ like the problem is on the underside. Hilarious as it sounds it was noticeable after taking the underside cover off again ha.
There is no where and I mean no where you can get esk8 related esc’s repaired here. I have tried. Can bus well then you can snip off the chips but DRV’s well no. If you find an Aussie wizard then share.
