For a lathe, probably a scroll chuck gripping your wheel pulley which is already centered on the wheel.
Or maybe a faceplate if you can get the holes to line up right.
Interesting. I read up on the cracking truck issue due to vibration. I just thought throw on a 97mm flywheel just be fast and simple.
I wanted to get a set of those MBS ATs for my V3 build on a raptor 1 deck, thatās not going to be an issue right?
Yep, I had edited to include the shape and contact patch as positives.
Thereās simply a shortage of quality skate wheel options above 80mm.
i guess if you already have a $70 set of wheels then lathing them down is a better option to getting another $90 in wheels?
I sort of want a lathe so i can do weird things. like this.
Iāve ridden on worn down MBS wheels for a time nowā¦ i can see the appeal. They donāt ride like abecs or kegels. Theyāre pretty distinct.
A quick observation You will need to flip that hanger to avoid scraping it in the ground when using the urethane and also to use the mounts.
Yeah I just realized that when I tried to slide the mounts in, I couldnāt mount them in the correct position.
Iāll switch the hangers tomorrow.
BTW is there an easy way to compress the springs to allow mounting them comfortably without scratching the baseplate?
Just apply pressure with your hands no tools need it.
