I’m running 80a orange kegels on my Unik board and I find the urethane too hard for my liking.
I don’t want to replace the pulleys if I can help it, so I’m looking for a softer alternative with the same hub in a 80mm or 83mm size as I’m not interested in bigger wheels.
I found the popocas better but they’re 90mm.
You might behave to look at pulleys change. I’d have thought there might be some cheap 12mm enertion pulleys out in the wild soon?
Can be done, not recommnded…¨
You ahve to be really carefull and skileld to make your pulley centered correctly, if it isnt than it overload your belt and the belt wont last long, or you will ahve to run it loose, which is not good idea But Jed boards are colaborating with Oranagatang company on making bigger (and probably softer) wheels, IDK if they will be sold separatly and for how much and when
