SOLD (gone): Flipsky 6354 190KV 2450W (location Idaho, USA)
$40
  • Purchased: October 2018
  • Used Nov 2018 > January 2019 (then winter came to Idaho)
  • And then I upgraded to 6374
In great condition, no issues.
  • Max Power: 2450 Watts
  • Max Current: 65 Amps
  • Max Volts: 12S
  • Max Torque: 7Nm
  • Motor Resistance: 0.053Ohm
  • Recommend ESC: 3-12S 50A
  • Weight: 1.23 lb / 0.56 kg
  • The motor length:54mm
  • The motor diameter: 63mm
  • SHAFT: Diameter 8mm, 24mm length, 3x3x15mm keyway slot.
  • Motor Wire: 130mm silicone 12AWG wire with 4.0mm Gold Bullet Connector Male.
  • Wire configuration:
  • Blue = A
  • Black = B
  • Yellow = C
  • BLDC Motor
  • The number of pole: 14
IMG_4244 IMG_4246 IMG_4247 IMG_4248
Great deal :confetti_ball: :partying_face:
GLWS
edited to Nov 18 > jan 19 …(not 18) :slight_smile:
SOLD and SHIPPED today
thx @rowjimmy77
