I’m selling a brand new Flipsky 4.20 Plus with integrated anti spark power switch and push to start. This VESC is brand new and I’ve only opened the plastic cover. It is insufficient for my setup as initially I was using the Carvon Exo’s as my motors but have moved to belt driven drive from Haggy Board.
Are you basing this off of @mmaner’s post on the Dual Flipsky 4.20?
If so, I believe the new Plus version is supposed to fix that problem based on other users if you do a search.
To be honest I never pushed it more than 20 apms motor max for my carvons. But based upon @mmaner review here,I never pushed it beyond 30 amps for fear of blowing it out.
Just because your motor is rated at 60a max doesn’t mean you will blow the VESC up, just limit each side to 50a and your good to go assuming you have the Dual Plus version.
Ok Thanks @mmaner . But will I not be not utilizing the full potential of my motors?
I mean to be honest if 10 amps doesn’t make that much of a difference and I have to spend another $100 to get a FS6.6 then i wont really bother with it.
