So let me get this straight just so I understand. You have disassembled 4 vescs and are now asking $73 each for someone to reassemble said vescs to continue your research into whether the cap upgrade works? Not sure thats a very good deal. Could be wrong though.
Erm no I did know what cap works because I had a recent thread and I have moved twords focboxes
Actually it wasn’t the reason why I had disassembled them it was because I intended to use two on my Spud and 2 on my mini build but never got to it and just used a cheap esc substitute
And partially because my antispark kept failing so I never finished my build🤣
are you selling these with 10awg wire and xt90’s and bullet connectors? because if someone wanted to buy these and assemble them they would also have to buy those parts and at that point would you not buy it from @torqueboards for $85 assembled?
Ouch, hope you recover, if there is instructions I could probably do it myself, any idea if it would work with this 800W motor. It is 3 phase and has the Hall sensors so it should work.
