SOLD - Two Flipsky Vescs. £90 Both including postage within the UK but open to splitting
Selling due to not needing them anymore. Perfect working order with new heatshrink (hence why the flipsky logo is no longer om the outside. Can post quickly and worldwide. Free Uk postage but overseas will depend on the location.
Information is below
1st Vesc specs:
  • Hardware:V4.12
  • Firmware: V3.40(Keep upgrated with the latest firmware version)
  • PCB:4 layers, size: 40*60mm
  • Current: 50A continuous / 240A peak
  • Voltage: 8V-60V (Cells: 3-13S LiPo)
  • Recommended 10S battery
  • BEC: [email protected]
  • BEC type: Internal driver support
  • Timing: Software calibration
  • Motor control interface: PPM signal (RC servo), analog, UART, I2C,
  • USB or CAN‐bus.
  • Cutoff Voltage: Programmable
  • Frequency: PWM input
  • Governor: No
  • Weight: 80g
  • FSESC4.12 Size: 60x40x20mm
  • Programming card: No
  • Reverse: Yes
2nd vesc specs:
  • Hardware:V4.20
  • Firmware: Latest Version
  • Amps: 50A continuous,instantaneous current 150A
  • Voltage: 8V-60V(Cells: 3-13S LiPo)
  • Governor: No
  • Weight: 76g
  • PCB Size: 39x46x17.4mm
  • Size:67x39x18.3mm(Include Heatsink)
  • Reverse: Yes
vesc1 vesc2
These are £90 new with warranty though?
Hi Anubis,
New they are $160 for both or £132
Everyone in the UK buys on ebay. They’re £85 for 2 4.12s on ebay.
Might be useful for people in the US though
its 51$ each on aliexpress for US
Will canbus work with these or do they need to be the exact same esc?
