Soldering iron advice
So i havent had a need for a soldering iron any of my past hobbies until now. So im new to soldering irons. What kind of wattage will i need and how hot does it need to get? I have about 50 usd to use on this and i wanted to ask first before i buy some random one from the auto shop i have near me and learn it isnt suitable.
I would seriously try to increase your budget and get a Weller WESD51.
If you must stay cheap, find the chunkiest looking Weller within your budget.
I was going to say the same thing until I saw the budget, then I left :rofl:
I’ve had many $50 ones fail but the WESD51 just always works, and works great.
For the price weller is a solid choice, also a very solid option is this little guy:
https://www.amazon.com/NovelLife-Mini-TS100-Soldering-Digital/dp/B07D35B75T/ref=sr_1_2_sspa?hvadid=176302638120&hvdev=c&hvlocphy=9031939&hvnetw=g&hvpos=1t2&hvqmt=e&hvrand=10724625757763024161&hvtargid=kwd-145719817977&keywords=ts100+soldering+iron&qid=1554861454&s=gateway&sr=8-2-spons&psc=1
It has the advantage of being small, portable and you can power it directly from RC lipo. (Or usb-C battery pack with a QC trigger, like I do)
This is a really high quality iron, you might think otherwise. Search for reviews online, everyone loves it.
It needs to be able to do 450C for many of these esk8 things
Weller 100% I have like 5 irons, for doing heavy lifting I go to the weller every time.
The only issue I’ve had with Weller was a pencil too becoming wallered out. Probably could’ve just drilled a hole or two for set screws, but I just bought a new pencil. It was probably my fault as I was hot swapping tips and tightening with channel locks.
You might also think about an FX888 from Hakko. More expensive, but it’ll save you a ton of frustration down the line with trying to solder stuff.
I should mention this will probably be the only thing i use it with. I dont do a whole lot other then wanting to do wires for batteries and connecting wire together.
I checked it out and honestly i think that one will be in my budget.
Hakko is good too! As long as you do some research and maybe watch a review video or two you should be fine. Most soldering irons are “you get what you pay for” category. The one exception being the small little guy I mentioned, but yeah for battery stuff you’ll want something with more punch.
Maybe I’ve gotten lucky… I found a cheapo $19 variable temperature, I think maybe 40W iron from microcenter that’s been going strong for about a year and a half, maybe two years. I couldn’t say what it is, some totally off brand, but I love it. It solders 10AWG and 5.5mm bullets great… But I’m thinking about picking up one of those cheap 100W $20 Weller irons for soldering 8AWG and below… I don’t want to hold heat on nickel longer than I need to.
TS100 or TS80
TS100 is about $55, TS80 is about $80, but includes everything you need.
TS80 has better performance.
Both irons feature temperature control, 100°C <-> 400°C.
TS80 can solder TO-220 drain tabs to 6"x6" ground plane, and I have no problems soldering 10 AWG wire with it.
Honestly, I’ve used a hakko benchtop station (cann’t remember which one) and the TS80 definitely beats it.
But you can become that guy with the soldering iron
And in a few years you’ll have so many panavises and homemade octopuses or third hands it’ll be great
I have this if your interest. 20190409_221759 20190409_221710
I think 450°C is much better for XT90 and battery stuff. It’s counterintuitive, but you can keep things cooler with a hotter iron.
@Lucajo16 You should take him up on the deal :wink: @Rithblu
That’s a professional unit.
Is this real 450°C or just a 450°C setting?
Flux vapourizes instantly above 350°C and almost every iron I’ve used oxidizes at those temperatures.
The tip technology has a much more significant impact on heat delivery than the temperature difference from my experience. As I said, it can solder a heatsink to a huge copper ground plane.
Just put a brand new tip on it just now to test.
The Weller WESD51 climbs to 850°F (454°C) and as soon as you touch it to something, it drops significantly but then climbs back up.
