I’m scratching my head now.
in BLDC, I tried to use Hall sensor. It detects but only jitter when tried to use the motor in at any amp/voltag/ throttle. Just Jitter.
Anyone knows why?
If I turn off Sensor Mode it works tho
right now values are 255, 6, 4, 5, 2, 1, 3, 255 there are only 6 wire so it is doing right. in the tap it show 225 as 6.
Only possibility I can think of is the extention I made. But even the sensor made in factory jitters could it be the wire prob?
Thanks for the help
NvM: I got it. it was Vesc tool error, it was set to -1 6 4 5 2 1 3 -1
I manually changed -1 to 6 now it works
Maybe this the problem I’m having with my Hall Sensor. I run motor dectection with the hall sensors and the motor spins fine dectects and everything. Once everything done, I pull my throttle and the motors don’t spin at all. Wonder what the issue could be could be
I don’t know how to calculate the settings manual for hall sensors
when u do the detection, the tool will show the values. take that and put into sensor tap and write the setting. and make sure u running the hybrid.
You would first select hybrid mode on the bldc setting manual before motor detecting ?
well it doen’t matter but thats what i did
Awesome. Whenever get the chance I’ll do that. Thanks for the topic
Hey dude. How did you change these values?
