So I got my board all set up and everything seems to be working fine except that my brakes don’t work when my battery is fully charged. Once it’s down to around 90%, everything works fine.
If I put on my brakes at 100% and my batteries are full, nothing happens. If I put on my brakes at 50% and I’m going slow, I get some braking. Once my battery is at 90% the issue is gone. Any ideas on where to start would be of much appreciated.
I’m running a Space Cell 3, Carvon Hub, VESC, Enertion Remote.
Your problem is regenerative braking and overcharge protection.
Your VESC is preventing the battery from being overcharged, and in order to do that it needs to disable breaks.
Could be a variety of things, but it does sound like what @link5505 mentioned. Though, I wouldn’t imagine you need to go all the way to 90% to stop it from happening. Another possibility is that you’re getting voltage spikes during regen that bring it over the max. Anyway you can plug it into your laptop and do active sampling to see if you get a fault code? You Might have to hold the brake down while turning the wheel during full charge to see it.
I agree with @link5505 this is a common story with VESC.
They use a dual-drive system. They describe it (albeit in a very basic way) here:
The solution for most of us with single drive, is to reduce braking force in BLDC. Then less energy is created when regen is happening, so you’re less likely to trip your VESC’s cutoff threshold. You could charge the battery just below max. The problem with this is it is at max charge, for most BMSs, where balancing happens.
When I know my battery is full, I avoid heavy extended braking for the first few minutes. That’s how I solve it personally, along with slightly reduced braking force settings.
@Mrmoonlight it sounds like you’re regen settings are not configured well for you setup, thus the sensitivity you’re experiencing. @onloop wrote a good post about it here, try manipulating the settings according to this post:
Sounds like one or more of your cells might’ve gone bad causing the overvolt during regen.
@treenutter The reason I’m hesitant to go to that conclusion is because that he needs to go all the way to 90% for the issue to go away. This should stop happening even at 98-99%. The settings seem correct for battery Regen according to his screenshot.
On the faq it says they have a secondary braking resistor to correct the problem. My theory is that the resistor reduces the voltage to prevent current from flowing back into the battery and it redirects the energy as heat to a sink.
I think it’s because it requires additional engineering due to it being a “secondary braking resistor” meaning it needs to have a primary one for actually regen braking when it’s not full. I could be completely wrong though, so a bit of a disclaimer there
