I just built a board using the single motor esc substitute from eBay.
I get an issue where the power cuts out when I’m accelerating.
Then the controller stops responding as if it lost connection.
Then I have to completely stop and wait like 3sec and the controller will reconnect and the board will go.
Happens 10x per trip. Only under hard acceleration.
Often times I’m accelerating up to 42km/h 26mph and its fine, no cutouts. But then I’ll stop and as soon as I start going the thing cuts out just as soon as power kicks in.
The power only cuts out when controller is in high mode. Medium mode is smoother acceleration and the power doesn’t cut out.
My setup: esc substitute. Same esc and controller as meepo boards. Allows up to 1350w power.
-6364 190kv motor 2000w
9s battery 5000mah 20c
The esc has a receiver built into it, and the receiver has a long antenna. I had the antenna close to the esc before, but then moved it away from esc and motor but still the power cuts out.
Anyone experience this?
UPDATE Fixed lose Connection, and not cutting out anymore. Read below for details.
I noticed burnt plastic insulation on one of the motor to esc wires. So it’s turned out to be a lose connection that sparked and burnt the insulation. I crimped it more thoroughly, and even soldered it. Will test it soon and see if it stops cutting out. It didn’t cut out when I first built this thing so the connection must’ve come lose over time. It also lost brakes when it would cut out, so that’s how I knew that it wasn’t hitting voltage cutoff, because low voltage cutoff lets you use brakes but not the throttle.
Pics of the lose connection : You can see the burnt insulation. That connection was lose as heck.
Yeah the esc is 10s version. With voltage cutoff at 3v per cell. But even fully charged my battery indicator shows 75% charged since I got 10s, and it still cuts out.
And when the battery is almost dead the cutouts are less.
This doesnt matter, Im assuming that because you didnt list another spec after your 9s battery, that the parallel count is 1. A 9s1p pack is going to sag like a titty if the cells are only rated for 20c
imo, your options are:
1: get a 10s battery
2: take one of the 3s lipos off and buy the 6s esc ( make sure you get the correct one, hub vs belt) and youll be all set
I guess that could be the case. I also fell hard going 40km/h and the controller took full force of my hand. It’s got a nice scrape on it. I took it apart and it seems to be ok inside.
Before that fall the board didn’t cut out. But it also didn’t start cutting out right after the fall. So I’m confused a bit.
This sounds like an ESC DRV error more than a remote error. Sounds like the ESC is failing under load(High amps) and the board is probably restarting or something.
in addition to voltage cutoff, power wires emit enough emf to interrupt radio signals.
like…if your controller wire is crossing the main power leads, the emf coming off the power leads can cause enough interruption to mess up the controller connection.
Yeah well I guess I can just ride it in medium mode for now. It still goes fast just the power doesn’t kick in as rapidly. That’s what’s causing the cutout, the moment the power kicks in in high mode.
Maybe a vesc is in order. This Chinese rec substitute is not even programmable.
I was considering that too because the motor is rated 2000w and battery can deliver 1850w. But the esc has a max of 1350w.
Also maybe the esc max amperage is lower than the battery? But how is that possible if the rec is made for 10s battery and I have a 9s.
Check if the breaks still work when the powercuts out as you are prob hitting the low voltage cut of of the esc due to you useing a 9s battery. these esc’s leave the breaking even when it cuts acceleration due to hitting the cutoff. if the breaks are still there get a 10s battery and it should be be good to go if not you have some other problem.
Update:
i rekon its hitting cutoff like the others are saying.
if it’s in the high mode like you said, it’ll draw more current, and make the battery sag more. At 10s, the cutoff voltage is most probably 32v ish.
so once your 9s battery hits about 3.6-3.7v per cell, the esc thinks its a 10s battery with low voltage. A relatively full (75% like you said) battery may sag to this point easily
