Nope, I don’t have a BMS installed (using a regular hobby charger at the moment). I’ll take a look at max ERPM and peak duty cycle next time I ride. Thanks for the suggestions.
It might as well be that it is all you need lol… at least that’'s what I think… Do you reach the max speed with full throttle or do you feel that the motor could go more and more?
Try to go uphill to see if there really is this limitation…
With 36v nominal and 15A = 540W…
Your second bet would be to try to accelerate very hard to see what the peak is…
So yeh, if you do find you cannot push past 15A up a hill or when accelerating hard, then the problem is probably in software or in electronics, not in the environment or in power you require…
The vesc “motor current” setting is limiting u. It gets confusing with the duty cycle and blah blah but the only way youre going to hit a true 35 amps is if u increase it or you put the motor under a large load at high speed (high duty cycle). Move ur motor amps up…or if u want to be more knowledgeable about what to set it to search for devins posts on buildanelectricboard.com since everything he wrote here got deleted or do akamaniacs software
I agree with @Hummie, try to increase your motor max or try Ackmaniac’s firmware which has the watt control mode (and it lets you draw an acceleration curve), my guess is that you’re limited by the current control mode + the motor max setting.
I increased my motor and battery max current to 60A and 50A respectively. Acceleration is noticeably quicker, however, motor peak power is still < 500w.
I tried climbing a small hill: duty cycle was hitting 0.8, I could hear the motor bogging down hard, but it refused to pull more than 380w. The pack voltage never dropped below 32v (battery low voltage cutoff start).
